kcl-samples → exhaust-manifold →
exhaust-manifold
// Exhaust Manifold
// A welded exhaust header for an inline 4-cylinder engine
// Set Units
// Define Constants
primaryTubeDiameter = 1.625
wallThickness = 0.080
plateHeight = 0.125
bendRadius = 3
// Create a function to draw each primary tube with specified lengths and angles
fn primaryTube(n, angle001, length001, length002, length003) {
// Create an index for the function
pos001 = n * 2
// Define a plane for each sweep path defined by an angle
sweepPlane = {
plane = {
origin = [pos001, 0.0, 0],
xAxis = [
sin(toRadians(-angle001)),
cos(toRadians(-angle001)),
0.0
yAxis = [0.0, 0.0, 1.0],
zAxis = [1.0, 0.0, 0.0]
// Draw a path for each sweep
sweepPath = startSketchOn(sweepPlane)
|> startProfileAt([0, plateHeight], %)
|> line(end = [0, length001])
|> tangentialArc({ offset = -80, radius = bendRadius }, %, $arc01)
|> angledLine({
angle = tangentToEnd(arc01),
length = length002
|> tangentialArc({ offset = 85, radius = bendRadius }, %, $arc02)
|> angledLine({
angle = tangentToEnd(arc02),
length = length003
// Create the cross section of each tube and sweep them
sweepProfile = startSketchOn('XY')
|> circle(
center = [pos001, 0],
radius = primaryTubeDiameter / 2
|> hole(circle(
radius = primaryTubeDiameter / 2 - wallThickness
|> sweep(path = sweepPath)
return { }
// Draw a primary tube for each cylinder with specified lengths and angles
primaryTube(0, 0, 3, 6, 5)
primaryTube(1, 1, 3, 6, 5)
primaryTube(2, 24.3, 5, 5, 3)
primaryTube(3, 25.2, 5, 5, 3)
// Create the mounting flange for the header
flangeSketch = startSketchOn('XY')
|> startProfileAt([3 + 1.3, -1.25], %)
|> xLine(length = -2.6, tag = $seg01)
|> tangentialArc({ radius = .3, offset = -40 }, %)
|> tangentialArc({ radius = .9, offset = 80 }, %)
|> xLine(length = -1.4, tag = $seg03)
|> yLine(length = segLen(seg01), tag = $seg04)
|> xLine(length = 3.1, tag = $seg05)
|> tangentialArc({ radius = 1.5, offset = 80 }, %)
|> xLine(length = segLen(seg05), tag = $seg07)
|> yLine(endAbsolute = profileStartY(%), tag = $seg08)
|> xLine(length = -segLen(seg03), tag = $seg09)
|> tangentialArcTo([profileStartX(%), profileStartY(%)], %)
// Create openings in the flange to accommodate each tube
|> hole(circle(
center = [0, 0],
|> hole(circle(
center = [2, 0],
|> hole(circle(
center = [4, 0],
|> hole(circle(
center = [6, 0],
// Add mounting holes to the flange
|> hole(circle(
center = [
-primaryTubeDiameter * .6,
radius = 0.25 / 2
|> hole(circle(
center = [
radius = 0.25 / 2
|> hole(circle(
center = [
3 * 2 - (primaryTubeDiameter * .6),
radius = 0.25 / 2
|> hole(circle(
center = [
3 * 2 + primaryTubeDiameter * .6,
radius = 0.25 / 2
// Extrude the flange and fillet the edges
|> extrude(length = plateHeight)
|> fillet(
radius = 1.5,
tags = [
getNextAdjacentEdge(seg04),
getNextAdjacentEdge(seg07)
|> fillet(
radius = .25,
tags = [
getNextAdjacentEdge(seg03),
getNextAdjacentEdge(seg08)
