kcl-samples → pipe-with-bend
pipe-with-bend
pipe-with-bend
// Pipe with bend
// A tubular section or hollow cylinder, usually but not necessarily of circular cross-section, used mainly to convey substances that can flow.
// Define constants
innerDiameter = 10
outerDiameter = 20
bendRadius = 30
bendAngle = 90
// create a sketch in the 'XZ' plane
sketch000 = startSketchOn("XZ")
// create a profile for the outer diameter
outerProfile = circle(
  sketch000,
  center = [bendRadius, 0],
  radius = outerDiameter / 2
// create a profile for the inner diameter
innerProfile = circle(
  sketch000,
  radius = innerDiameter / 2
// create the profile of the pipe
pipeProfile = outerProfile
  |> hole(innerProfile, %)
// revolve the pipe profile at the desired angle
pipe = revolve({ axis = "Y", angle = bendAngle }, pipeProfile)
