kcl-samples → food-service-spatula →
// Food Service Spatula
// Use these spatulas for mixing, flipping, and scraping.
// Define constants in millimeters (mm)
flipperThickness = 3.5
flipperLength = 70.0
handleWidth = 15.0
gripLength = 150.0
flipperFilletRadius = 5.0
flipperSlotWidth = 10.0
gripWidth = 10.0
gripHeight = 20.0
gripFilletRadius = 3.0
gripSlotWidth = 8.0
// function for drawing slots on a sketch given the start and end points as well as a width
fn slot(sketch1, start, end, width) {
angle = if start[0] == end[0] {
if end[1] > start[1] {
90
} else {
270
} else {
if end[0] < start[0] {
toDegrees(atan((end[1] - start[1]) / (end[0] - start[0]))) + 180
} else {
toDegrees( atan((end[1] - start[1]) / (end[0] - start[0])))
dist = sqrt(pow(end[1] - start[1], 2) + pow(end[0] - start[0], 2))
xstart = width / 2 * cos(toRadians(angle - 90)) + start[0]
ystart = width / 2 * sin(toRadians(angle - 90)) + start[1]
slotSketch = startProfileAt([xstart, ystart], sketch1)
|> angledLine({ angle = angle, length = dist }, %, $line000)
|> tangentialArc({ radius = width / 2, offset = 180 }, %, $arc000)
|> angledLine({ angle = angle, length = -dist }, %, $line001)
|> tangentialArcTo([profileStartX(%), profileStartY(%)], %, $arc001)
return slotSketch
// create a sketch on the "XY" plane
sketch000 = startSketchOn('XY')
// create a profile of the flipper
flipperProfile = startProfileAt([-flipperLength, -32.0], sketch000)
|> line(end = [flipperLength, 2.0])
|> yLine(length = 60.0, tag = $backEdge)
|> line(end = [-flipperLength, 2.0])
|> arc({
angleEnd = 196.912390,
angleStart = 163.087610,
radius = 110.0
// create a profile of the middle
slotProfile000 = slot(sketch000, [-25, 0], [-55, 0], flipperSlotWidth)
// create a profile of the top slot
slotProfile001 = slot(sketch000, [-25, 18], [-55, 19], flipperSlotWidth)
// create a profile of the bottom slot
slotProfile002 = slot(sketch000, [-25, -18], [-55, -19], flipperSlotWidth)
// create a profile with slots for the spatula
spatulaProfile = flipperProfile
|> hole(slotProfile000, %)
|> hole(slotProfile001, %)
|> hole(slotProfile002, %)
// extrude the profile to create the spatula flipper
flipper = extrude(spatulaProfile, length = flipperThickness)
// fillet the edges of the flipper
fillet(
flipper,
radius = flipperFilletRadius,
tags = [
getNextAdjacentEdge(backEdge),
getPreviousAdjacentEdge(backEdge)
// create a sketch on the "XZ" plane offset by half the thickness
sketch001 = startSketchOn(offsetPlane("XZ", offset = -handleWidth / 2))
// create a profile of the spatula handle
handleProfile = startProfileAt([0.0, flipperThickness], sketch001)
|> line(end = [31.819805, 31.819805], tag = $handleBottomEdge)
|> line(end = [140.953893, 51.303021])
|> line(end = [-1.710101, 4.698463])
|> line(end = [-141.995517, -51.682142], tag = $handleTopEdge)
|> line(end = [-36.139148, -36.139148])
|> xLine(length = 7.071068)
// create an extrusion extrude001
handle = extrude(handleProfile, length = handleWidth)
// fillet the bend of the spatula handle
fillet(
handle,
radius = 4,
tags = [
getNextAdjacentEdge(handleBottomEdge),
getNextAdjacentEdge(handleTopEdge)
// define a plane which is at the end of the handle
handlePlane = {
plane = {
origin = [208.593833, 0.0, 75.921946],
xAxis = [0.342020, -0.0, -0.939693],
yAxis = [0.0, 1.0, 0.0],
zAxis = [0.939693, -0.0, 0.342020]
// create a sketch on the handle plane
sketch002 = startSketchOn(handlePlane)
// create a profile of the grip
gripProfile = startProfileAt([-26.806746, -10.0], sketch002)
|> xLine(length = gripWidth - (2 * gripFilletRadius))
|> arc({
angleStart = -90.0,
angleEnd = 0.0,
radius = gripFilletRadius
|> yLine(length = gripHeight - (2 * gripFilletRadius))
|> arc({
angleStart = 0.0,
angleEnd = 90.0,
|> xLine(length = -(gripWidth - (2 * gripFilletRadius)))
|> arc({
angleStart = 90.0,
angleEnd = 180.0,
|> yLine(length = -(gripHeight - (2 * gripFilletRadius)), tag = $gripEdgeTop)
|> arc({
angleStart = 180.0,
angleEnd = 270.0,
// extrude the grip profile to create the grip
grip = extrude(gripProfile, length = -gripLength)
// create a sketch on the grip for the hole
sketch003 = startSketchOn(grip, gripEdgeTop)
// create a profile for the grip hole
gripHoleProfile = slot(sketch003, [0, 200], [0, 210], gripSlotWidth)
// cut a hole in the grip
extrude(gripHoleProfile, length = -gripWidth-20)
