kcl-samples → gridfinity-bins-stacking-lip
// Gridfinity Bins With A Stacking Lip
// Gridfinity is a system to help you work more efficiently. This is a system invented by Zack Freedman. There are two main components the baseplate and the bins. The components are comprised of a matrix of squares. Allowing easy stacking and expansion. This Gridfinity bins version includes a lip to allowable stacking Gridfinity bins
// Set units in millimeters (mm)
// Define constants
binLength = 41.5
binHeight = 7.0
binBaseLength = 2.95
binTol = 0.25
binThk = 1.2
cornerRadius = 3.75
firstStep = 0.8
secondStep = 1.8
thirdStep = 2.15
magOuterDiam = 6.5
magOffset = 4.8
magDepth = 2.4
lipRadius = 0.5
lipStep1 = 1.4
lipStep2 = 1.2
lipStep3 = 0.7
lipStep4 = 1.8
lipStep5 = 1.9
// Number of bins in each direction
countBinWidth = 2
countBinLength = 3
countBinHeight = 1
// The total height of the baseplate is a summation of the vertical heights of the baseplate steps
height = firstStep + secondStep + thirdStep
lipHeight = lipStep1 + lipStep2 + lipStep3 + lipStep4 + lipStep5
// define a function which builds the profile of the baseplate bin
fn face(plane) {
  faceSketch = startSketchOn(plane)
    |> startProfileAt([binBaseLength + binTol, 0], %)
    |> yLine(length = height)
    |> xLine(length = -binBaseLength)
    |> angledLineOfYLength({ angle = -45, length = thirdStep }, %)
    |> yLine(length = -secondStep)
    |> angledLineOfYLength({ angle = -45, length = firstStep }, %)
  return faceSketch
// extrude a single side of the bin
singleSide = extrude(face(offsetPlane("YZ", offset = cornerRadius + binTol)), length = binLength - (cornerRadius * 2))
// create the other sides of the bin by using a circular pattern
sides = patternCircular3d(
  singleSide,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    (binLength + 2 * binTol) / 2,
    0
  instances = 4,
  rotateDuplicates = true
// define an axis axis000
axis000 = {
  custom = {
    axis = [0.0, 1.0],
    origin = [
      cornerRadius + binTol,
// create a single corner of the bin
singleCorner = revolve({ angle = -90, axis = axis000 }, face(offsetPlane("YZ", offset = cornerRadius + binTol)))
// create the corners of the bin
corners = patternCircular3d(
  singleCorner,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    0
  instances = 4,
singleBinFill = startSketchOn("XY")
  |> startProfileAt([
  |> line(end = [binLength - (binBaseLength * 2), 0], tag = $line000)
  |> line(end = [0, binLength - (binBaseLength * 2)], tag = $line001)
  |> xLine(endAbsolute = profileStartX(%), tag = $line002)
  |> close(tag = $line003)
  |> extrude(length = height)
  |> fillet(
       radius = firstStep,
       tags = [
         getNextAdjacentEdge(line000),
         getPreviousAdjacentEdge(line000),
         getNextAdjacentEdge(line002),
         getPreviousAdjacentEdge(line002)
magCutout000 = startSketchOn(singleBinFill, "start")
  |> circle(
       center = [
         -magOffset - binBaseLength - binTol,
         magOffset + binBaseLength + binTol
       radius = magOuterDiam / 2
  |> patternCircular2d(
       arcDegrees = 360,
       center = [
         (-binLength + 2 * binTol) / 2,
       instances = 4,
  |> extrude(length = -magDepth)
// create the baseplate by patterning sides
binSides = patternLinear3d(
       sides,
       axis = [1.0, 0.0, 0.0],
       instances = countBinWidth,
       distance = binLength + binTol * 2
  |> patternLinear3d(
       axis = [0.0, 1.0, 0.0],
       instances = countBinLength,
// create the corners of the baseplate by patterning the corners
binCorners = patternLinear3d(
       corners,
  |> patternLinear3d(
// create the fill of the bin by patterning the corners
binFill = patternLinear3d(
       singleBinFill,
  |> patternLinear3d(
binTop = startSketchOn(offsetPlane("XY", offset = height))
  |> startProfileAt([0, 0], %)
  |> xLine(length = (binLength + 2 * binTol) * countBinWidth, tag = $line010)
  |> yLine(length = (binLength + 2 * binTol) * countBinLength, tag = $line011)
  |> xLine(endAbsolute = profileStartX(%), tag = $line012)
  |> close(tag = $line013)
  |> extrude(length = binHeight * countBinHeight)
  |> fillet(
       radius = cornerRadius,
       tags = [
         getNextAdjacentEdge(line010),
         getPreviousAdjacentEdge(line010),
         getNextAdjacentEdge(line012),
         getPreviousAdjacentEdge(line012)
  |> shell(faces = ["end"], thickness = binThk)
fn lipFace(plane) {
    // |> yLine(length = lipHeight, tag = $line100)
    |> line(end = [0.0, 5.792893], tag = $line000)
    |> arc({
         angleStart = 180.0,
         angleEnd = 45.0,
         radius = 0.500000
       }, %, $arc000)
    // |> angledLineOfYLength({ angle: -45, length: lipStep5 }, %)
    |> line(end = [1.046447, -1.046447], tag = $line001)
    |> yLine(length = -lipStep4)
    |> angledLineOfYLength({ angle = -45, length = lipStep3 }, %)
    |> yLine(length = -lipStep2)
    |> angledLineOfYLength({ angle = -135, length = lipStep1 }, %)
  return faceSketch
plane000 = {
  plane = {
    origin = [
      cornerRadius,
      0.0,
      height + binHeight * countBinHeight
    xAxis = [0.0, 1.0, 0.0],
    yAxis = [0.0, 0.0, 1.0],
    zAxis = [1.0, 0.0, 0.0]
plane001 = {
  plane = {
    origin = [
      0.0,
      cornerRadius,
    xAxis = [1.0, 0.0, 0.0],
    zAxis = [0.0, 1.0, 0.0]
plane002 = {
  plane = {
    origin = [
      countBinWidth * (binLength + 2 * binTol) - cornerRadius,
      0.0,
// extrude a single side of the lip of the bin
lipSingleLength = extrude(lipFace(plane000), length = binLength * countBinWidth - (2 * cornerRadius) + 2 * binTol * countBinWidth)
lipSingleWidth = extrude(lipFace(plane001), length = binLength * countBinLength - (2 * cornerRadius) + 2 * binTol * countBinLength)
// create the other sides of the lips by using a circular pattern
lipLengths = patternCircular3d(
  lipSingleLength,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    (binLength + 2 * binTol) / 2 * countBinWidth,
    (binLength + 2 * binTol) / 2 * countBinLength,
    0
  instances = 2,
lipWidths = patternCircular3d(
  lipSingleWidth,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    0
  instances = 2,
axis001 = {
  custom = {
    axis = [0.0, 1.0],
    origin = [cornerRadius, cornerRadius]
lipSingleLengthCorner = revolve({ angle = -90, axis = axis001 }, lipFace(plane000))
lipSingleWidthCorner = revolve({ angle = 90, axis = axis001 }, lipFace(plane002))
lipCorners000 = patternCircular3d(
  lipSingleLengthCorner,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    0
  instances = 2,
lipCorners001 = patternCircular3d(
  lipSingleWidthCorner,
  arcDegrees = 360,
  axis = [0, 0, 1],
  center = [
    0
  instances = 2,
