kcl-samples → router-template-slate
// Router template for a slate
// A guide for routing a slate for a cross bar.
// Set Units
// Define constants
routerDiameter = 12.7
templateDiameter = 11 / 16 * inch()
templateGap = (templateDiameter - routerDiameter) / 2 - 0.5
slateWidthHalf = 41.5 / 2
minClampingDistance = 50 + 30
templateThickness = 10
radius = 10
depth = 30
length001 = slateWidthHalf - radius
length002 = depth + minClampingDistance
// Create the first sketch
sketch001 = startSketchOn('XZ')
  |> startProfileAt([0, depth - templateGap], %)
  |> xLine(length = length001, tag = $seg01)
  |> arc({
       angleEnd = 0,
       angleStart = 90,
       radius = radius - templateGap
  |> yLine(endAbsolute = -templateGap * 2 - (templateDiameter / 2), tag = $seg05)
  |> xLine(endAbsolute = slateWidthHalf + templateThickness, tag = $seg04)
  |> yLine(length = -length002, tag = $seg03)
  |> xLine(endAbsolute = ZERO, tag = $seg02)
  // |> line(end = [7.78, 11.16])
  |> xLine(length = -segLen(seg02))
  |> yLine(length = segLen(seg03))
  |> xLine(length = segLen(seg04))
  |> yLine(length = segLen(seg05))
  |> arc({
       angleEnd = 90,
       angleStart = 180,
// Extrude the first sketch
extrude001 = extrude(sketch001, length = 5)
// Create the second sketch
sketch002 = startSketchOn(extrude001, 'START')
  |> startProfileAt([
       -slateWidthHalf,
  |> xLine(length = -7, tag = $rectangleSegmentA001)
  |> angledLine([
       segAng(rectangleSegmentA001) + 90,
       minClampingDistance
     ], %, $rectangleSegmentB001)
  |> angledLine([
       segAng(rectangleSegmentA001),
       -segLen(rectangleSegmentA001)
     ], %, $rectangleSegmentC001)
// Extrude the second sketch
extrude002 = extrude(sketch002, length = 7.5)
// Create the third sketch
sketch003 = startSketchOn(extrude001, 'START')
  |> startProfileAt([
       slateWidthHalf,
  |> xLine(length = 7, tag = $rectangleSegmentA002)
  |> angledLine([
       segAng(rectangleSegmentA002) - 90,
       minClampingDistance
  |> angledLine([
       segAng(rectangleSegmentA002),
       -segLen(rectangleSegmentA002)
// Extrude the third Sketch
extrude003 = extrude(sketch003, length = 7.5)
