kcl-samples → mounting-plate →
mounting-plate
// Mounting Plate
// A flat piece of material, often metal or plastic, that serves as a support or base for attaching, securing, or mounting various types of equipment, devices, or components.
// Set Units
// Define constants
plateLength = 10
plateWidth = 6
filletRadius = 0.5
plateThickness = .5
centerHoleDiameter = 2
// Create a function that defines the body width and length of the mounting plate. Tag the corners so they can be passed through the fillet function.
fn rectShape(pos, w, l) {
rr = startSketchOn('XY')
|> startProfileAt([pos[0] - (w / 2), pos[1] - (l / 2)], %)
|> line(endAbsolute = [pos[0] + w / 2, pos[1] - (l / 2)], tag = $edge1)
|> line(endAbsolute = [pos[0] + w / 2, pos[1] + l / 2], tag = $edge2)
|> line(endAbsolute = [pos[0] - (w / 2), pos[1] + l / 2], tag = $edge3)
|> close(tag = $edge4)
return rr
// Define the hole radius and x, y location constants
holeRadius = .25
holeIndex = .75
// Create the mounting plate extrusion, holes, and fillets
rs = rectShape([0, 0], plateWidth, plateLength)
part = rs
|> hole(circle(
center = [
-plateWidth / 2 + holeIndex,
plateLength / 2 - holeIndex
radius = holeRadius
|> hole(circle(
center = [
plateWidth / 2 - holeIndex,
radius = holeRadius
|> hole(circle(
center = [
-plateLength / 2 + holeIndex
radius = holeRadius
|> hole(circle(
center = [
radius = holeRadius
|> hole(circle(
center = [0, 0],
radius = centerHoleDiameter
|> extrude(length = plateThickness)
|> fillet(
radius = filletRadius,
tags = [
getPreviousAdjacentEdge(rs.tags.edge1),
getPreviousAdjacentEdge(rs.tags.edge2),
getPreviousAdjacentEdge(rs.tags.edge3),
getPreviousAdjacentEdge(rs.tags.edge4)
